Channel expression referencing a toggle not working
SteveNi
Hi
In my scene I have a null node called "Precise_Clipping "where I edited the parameter interface and added a toggle called "precise_clip" then In the voxel size channel of a vdb node I have written the following:
if (ch("../Precise_Clipping/precise_clip") == 1)
    return 0.01;
else
    return 0.2;
The problem here is that it gives this error:
http://prntscr.com/cg15f2
Its not the first time I write expression in channel fields, and to me the syntax looks correct...so whats the error?
Thanks
Edited by SteveNi
I think you have to enclose the whole lot in curly brackets for a multi line expression in a channel field. You can write it like this
float clip = 0.2;
clip = if(ch("../Precise_Clipping/precise_clip"), clip, 0.01);
return clip;
Edited by j00ey
typo in expression
float clip = 0.2;
value = if(ch("../Precise_Clipping/precise_clip"), clip, 0.01);
return clip;
Oh Yea I forgot that...dumb me.
Thanks a lot for the reminder :D
