How to save a frame in mantra ?
Hello!
I'm kind of new to Houdini and when I save a frame in mantra ( file > save fram as... ) it doesn't keep the real color which are displayed in my mantra render.
I tried TIFF, TGA, JPEG 100% and nothing worked, colors are still different from the one coming out of my mantra render..
Any idea how to keep the exact same color ?
Need help, have a nice day guys!
Fay
Two quick things to check, firstly that you have 'Convert to Image Formats colourspace' checked on in the 'Save As' dialog box. Secondly that you don't have any adjustments or LUTs being applied to your image in the render window (adjustments are along the bottom - If you're looking at the IPR window you might have to click the little arrow at the bottom right to pop the adjustments up).
Do you have the same problem with an EXR?
