New Pops: Where has the justhit Attribute gone?
gerd
Hallo,
i want to group particles that had just collided with an static object. They only should be in the group the timestep of the collision. After that timestep they should not be in the group anymore. In old pops you can use the justhit attribute inside the rule of the pop group node. ($JUSTHIT == 1)
greetings
gerd
I think it has been replaced with DOPs Impact record system. This data only exists on the frame when the impact occurs. But you can setup a solver to record the data to persist over time. I demonstrate such a setup in my particles break Glue Bonds video ~3:20 into it.
The video is fairly short, it may help you out.
