shawn_kearney Posted September 19, 2016 Share Posted September 19, 2016 (edited) I've always been a bit confused about how to get robust, user-defined advection into a simulation. Thus far the best method I've come across is to deform a plane and use the dot product between the normal and the initial velocity vector (sorry if my phrasing here is not accurate), plug this into the velocity attribute and generate a volume to use within DOP. And this does work pretty well, is very efficient and straightforward. Advection follows the geometry pretty much as I expect it to. But I often find my solutions are seldom the best practices and later discover it falls short in some major way. How do you go about "directing" your simulations? Edited September 19, 2016 by shawn_kearney Quote Link to comment Share on other sites More sharing options...
6ril Posted September 20, 2016 Share Posted September 20, 2016 Hey, oddly I started quite the same conversation, 4 hours before your post, you might want to have a look at it : Quote Link to comment Share on other sites More sharing options...
