How to contain a fluid in a closed container
arghap
Hello,
I got a closed water tank which contains the fluid inside. So the initial setup for my shot is working fine where the fluid is inside the tank.
I have a RBD simulation for the water tank which starts at frame 200 and I cached out the simulation and reading that in the fluid simulation as a static object with deforming geometry. Till frame 200 the fluid contained inside the tank is working fine but after frame 200 when the tank starts to break 80% of the fluid disappear. How the fluid goes missing when the tank started to deform?
Any help will be much appreciated.
Thank You!!
