connect segments for carve
Follyx
the "Join" SOP is used for that, its important for the vertex numbers of all the segments to be ordered correctly, for the Join SOP to give a correct result.
An alternative, that does work is the "FindShortestPath" SOP, which lets you draw new poly-line primitives between any interconnected primitives.
