Mask+particles
MADjestic
Hello,
Is it possble to create a mask that produces particles?  So that particles could only appear in certain areas according to the mask (P.y or whatever).  To be short I drew a small pic, illustrating the problem:
Thanks.
17703[/snapback]
You could also use attribute transfer
referring to you diagram, You could add point colors to your polysphere and animate the
sphere's motion through a grid. using attribute transfer you could transfer these color attributes,
based on proximity, to the grid. You could then use the transfered attributes on your grid to
trigger your particles.
