jim c Posted September 24, 2016 Share Posted September 24, 2016 I've got a tree that's generated via the L System SOP. I'm extracting the end points of the branches to grow leaves on them, after running the points through a SOP Solver to add some custom pt attribute data used in growing and animating the leaves. I notice that the point ids kind of jump all over the place as the lsystem grows over time. Is there a way to get a stable set of points such that the oldest point is point 0, and the next is point 1, and so on? Is it just a matter of sorting the points by age? Quote Link to comment Share on other sites More sharing options...
sebkaine Posted September 24, 2016 Share Posted September 24, 2016 have you check point attribute in your lsystem it give you all you need by default ? cheers E lage.hiplc Quote Link to comment Share on other sites More sharing options...
jim c Posted September 24, 2016 Author Share Posted September 24, 2016 Thanks, but here's what I'm talking about - I want to track one specific point as the lsystem grows. See these screenshots from your file: So that's frame 1 above, and that's the point I want to track - I've resorted by lage Now as the frames changes (frame 14 above), the point switches as well, now the point I wanted to track (circled in red) gets missed and instead I'm left with a different point. And then a few frames later it switches again: This is what I'd like to prevent. I think what I'm after is something like how a particle system treats id, so that they are stable as the system grows? Quote Link to comment Share on other sites More sharing options...
sebkaine Posted September 25, 2016 Share Posted September 25, 2016 (edited) i see your point jim in fact it is easy to isolate the extremity point (cf hip) but if you want to isolate 1 specific extremity point that is far more tricky ... The things is that you miss a crucial attribute, the id of the previous gen point that create the current extremity. If it was me i would base my growth setup either on - POP recursive stuff + pcopen stuff to control proximity OR - growth stuff throw seed propagation into sop solver However to solve this in L-system - i would start from the last frame and isolate it as ref frame - invert the anim and try to look at the closest point at each frame. but i haven't suceed yet ... cause point disapear and track this is not obvious ! lsystem_002.hiplc Edited September 25, 2016 by sebkaine Quote Link to comment Share on other sites More sharing options...
jim c Posted September 26, 2016 Author Share Posted September 26, 2016 Thanks. I sort of found a work around (I was able to use a bounding sphere to select a small group of points and then since the point I wanted was closest to the ground, just sorted by Y). But ultimately it would be nicer to have a general solution. Quote Link to comment Share on other sites More sharing options...
