permissions to edit file
girtab
it looks like you're trying to edit a Houdini hda - these are write protected
if you are just making changes that can live in that hip file - make the changes using the Edit Parameter Interface dialog - click the gear icon at the top right of the parameter pane
if you want to create a NEW File Cache SOP - change the Save To field at the very top to somewhere you have permission to access - be sure to give the new hda a unique name.
