Creating geometry for wire objects
art3mis
Hi
Going thru a tutorial on simulation caching and wire deforming by Scott Pagano.
One thing that is missing is the general steps for creating the geometry needed any time you use the wire object in Houdini.
At minimum you need at least 2 'linked' mesh objects,
1-wires representing the shape of the mesh to be deformed
and
2- the actual high resolution mesh
optionally a low resolution proxy mesh would come in handy.
I use Modo for modelling, but I guess the general principal might apply regardless of the modelling environment.
Edited by eco_bach
