Blacklisted_Guy Posted October 3, 2016 Share Posted October 3, 2016 Hello houdini wizards, I've been trying to make a script that makes a curve out of a bunch of points by finding the closest point. For some reason though, the points don't connect to their closest point File with the script in action as well as the script down below. //-----------------------------------------// // Find closest point V1 // // By Jonne Geven // //-----------------------------------------// //imported functions //returns: [0] = 2D distance. [1] = 3D distance vector2 distanceToPoint(int currentPoint; int targetPoint; int currentPointInput; int targetPointInput) { //importing user inputs int cp = currentPoint; int cpi = currentPointInput; int tp = targetPoint; int tpi = targetPointInput; //extracting point position vector cpp = point(cpi, "P", cp); vector tpp = point(tpi, "P", tp); //deltas float dx = tpp[0] - cpp[0]; float dy = tpp[1] - cpp[1]; float dz = tpp[2] - cpp[2]; //2d distance float DD2; DD2 = sqrt((dx * dx) + (dz * dz)); //3d distance float DD3; DD3 = sqrt((DD2 * DD2) + (dy * dy)); vector2 distances = set(DD2, DD3); return distances; } //closest point int closePoint(int currentPoint;int currentPointInput; int targetPointInput) { int tpc = npoints(targetPointInput); //this used to be user defined but that doesnt work since it needs to be the amount of points int cp = currentPoint; int cpi = currentPointInput; int tpi = targetPointInput; float C; float CP; int returnValue; for(int i = 0; i < tpc; i++) { //distance between points C = distanceToPoint(cp, i, cpi, tpi)[0]; //importing Z values vector zvalT = point(tpi, "P", i); vector zvalC = point(cpi, "P", cp); if(zvalT[2] < zvalC[2]) //comparing the target and current z position to make sure { //the curve has a direction //max search distance and making sure the processed point isn't selected. if(abs(C) < 19 && C != 0) { if(i != 0) { //comparing current distance to currently smallest distance if(C < CP) { CP = C; returnValue = i; } } //initializing CP value with first distance else if(i == 0) { CP = C; returnValue = 0; } } } } return returnValue; } //finding closestpoint i@target = closePoint(@ptnum, 0, 0); //This script is made with the general direction being -Z //vector pp0 = point(geoself(), "P", @ptnum); //vector pp1 = point(geoself(), "P", target); int line = addprim(0, "polyline"); addvertex(0, line, @ptnum); addvertex(0, line, @target); //-----------------------------------------// // For questions // // odforce: Blacklisted_Guy // //-----------------------------------------// closestPointNotFound.hiplc Quote Link to comment Share on other sites More sharing options...
Atom Posted October 3, 2016 Share Posted October 3, 2016 Hmm..am I reading that right? You are declaring your return value from distanceToPoint as a float yet you are returning a vector2. Is that the intention? These kinds of scripts often work better when running in detail mode(only once). Search this site, I remember a recent thread where there were multiple solutions to this problem provided. Quote Link to comment Share on other sites More sharing options...
Blacklisted_Guy Posted October 3, 2016 Author Share Posted October 3, 2016 On 10/3/2016 at 2:39 PM, Atom said: Hmm..am I reading that right? You are declaring your return value from distanceToPoint as a float yet you are returning a vector2. Is that the intention? These kinds of scripts often work better when running in detail mode(only once). Search this site, I remember a recent thread where there were multiple solutions to this problem provided. Expand yes, the distanceToPoint function returns a vector with the 2D distance between the points and a 3D distance. So, what you'd suggest is running the script with a for loop in detail mode instead of in point mode? I'll try that one! Thank you for the advice! Quote Link to comment Share on other sites More sharing options...
Atom Posted October 3, 2016 Share Posted October 3, 2016 Running in Detail mode you do loose VEX's multi-processor benefit so in these cases python becomes a viable alternative as well. When looping over points in detail mode it is sometimes easier to create flags to remember if you have already detected a candidate. When running under points you have no "memory" of the last point unless you construct some way to store variables as detail attributes. Here is the thread I was referring to up above. 1 Quote Link to comment Share on other sites More sharing options...
Blacklisted_Guy Posted October 3, 2016 Author Share Posted October 3, 2016 On 10/3/2016 at 2:53 PM, Atom said: Running in Detail mode you do loose VEX's multi-processor benefit so in these cases python becomes a viable alternative as well. When looping over points in detail mode it is sometimes easier to create flags to remember if you have already detected a candidate. When running under points you have no "memory" of the last point unless you construct some way to store variables as detail attributes. Here is the thread I was referring to up above. Expand thank you for the link, I'll be looking through it! Quote Link to comment Share on other sites More sharing options...
