NachoG Posted October 3, 2016 Share Posted October 3, 2016 (edited) Hi guys! Firstly first. My name is Nacho and this is my first message in this amazing forum. I'm a newer to Houdini, so please, bear with me and my English language as well I've prepared a very basic file to try to explain you my issue with this cloud animation, consisting basically in a cloud (using cloud and cloudnoise nodes) and a DOP network which I would like to use to give some turbulence to my original generated cloud. This is my issue: (please, open the attached file for more understanding) I animated the offset of the noise of one of my volume VOP nodes used (cloud_DeformationNoise4 (blue colored in my file)) to give some variation in time to that shape. It's a very basic and exaggerated animation just to show you the issue. So at that point, inside the cloud generation process, no issues are found. But when I try to import that cloud within a DOP network, the original noise animation is completely lost. Since I'm using a setup file from a work college, I did the basic procedure from scratch in a new file and it worked like a charm, so I can't understand why it's not working with my college´s setup. Could any of you (ohhh true Masters of Houdini) be so kind to have a look to the attached file and tell me what I am doing wrong? Looking forward to hearing from you guys. I have been breaking my head with this (probably stupid) issue for too long. I'll be eternally grateful :_ ) Cheers! test_cloud_animation.hipncFetching info... Edited October 3, 2016 by NachoG Quote Link to comment Share on other sites More sharing options...
galagast Posted October 6, 2016 Share Posted October 6, 2016 Iinside dopnet1, on your sourcevolume1 node, did you try removing the expression on the Scale Source Volume parameter ($F == 1)? Quote Link to comment Share on other sites More sharing options...
