(NOVICE) Attatch POP Grains to deforming geometry
derjcmp
Hello. Do you want the POPs to "stick and stay" on the deforming geometry surface? I am unfortunately no guru, so my attached solution is not maybe ideal. But it is working for me. Further about the collisions, I recommend you also this ... https://vimeo.com/182074285  ... at the beginning, Jeff talks about the Deforming Object shelf tool and more about the volume collisions and static solvers and troubleshooting.
attach pops - v0.hiplc
That wasnt the type of effect I was looking for, however it showed me a good technique I didnt know!
The type of effect Im after tho is like having a Derfoming geometry with the grains all over the surface on frame 1 and moving with with the geo until the end. I tried sticking them in a static position and then interpolating it with the deformed geo after the simulation, but that didnt make any sense in my head nor in houdini. I thought It had to be an easier way, perhaps through a multisolver and some vex, idk.
Thank you.
Hello João, I see. I think that this may also help you:
http://lab.ikoon.cz/post/148412813139/inspired-by-the-sop-examples
I made that file from the help example file (SpikyDeformingTorus.otl) and I use the Attribute Interpolate. However, it is not a DOP, but SOP solution:
https://www.sidefx.com/docs/houdini/nodes/sop/attribinterpolate
That example file is well documented and it may also help you :)
I was looking for a dop solution :/ I've tried your method but didnt give me the results I was after.
I'm going for an effect like this:
The fallof part I can easily do, however sticking the grains to the geo is really hard
  • 3 months later...
Did you suss this out J ?
It's something I want to do too.. fill an object with grains and have them deform with my alembic mesh.
Just thinking on my feet.. essentially they are all connected via a glue network of connected lines.. it may be easier to deform that as such and hopefully the grains will go for the ride till you choose to break them?
I didn't manage to pull this off :(
I tried like 10 different approaches and all of them didn't work as I wanted. I could stick them as scattered points and add a copySOP to make them grain like then doing a RBD sim, but I couldn't get that particle to particle interaction without heavy compute time...
I asked it on /r/houdini and some pretty cleaver solutions came through, will give it a try when I have more time!
1 hour ago, mestela said:
Doh, immediately after I posted realised how to make it be fully dynamic rather than switch, if you need that level of detail. Here I've ramped the targetstiffness from 0 at the feet to 1 near his waist, then turn it off completely after frame 41.
grain_dancer_v02.hipnc
Went through the file, pretty cleaver! I guess I still have a long way to go inside houdini. Thanks matt!
  • Like 2
its insane - there must be 50 ways to do every trick in houdini its scary.  There was a bit of wrangle in there that just made me go 'huh'
i'm not adverse to it at all but i have no idea whats happening with each bit really and i cant help but think 'is there a sop solution to this for my noobness to get my head around' lol
I went through and added some AA noise, did a fit range and mult it by the stifeness, Im getting exelent results!
Also did another wrangle so it would colapse if @targetstifness was < 0.3 . I guess I'll be playing with this all night!
Edited by derjcmp
1 minute ago, anthonymcgrath said:
jeez i've no idea what you just said but it sounds cool lol!
Instead of having ramped the targetstiffness from 0 at the feet to 1 near his waist I did a noise. So some parts start to crumble as the others just follow the geometry :)
ooooooooooooooooo that sounds smutty!!  :D  cant wait to see that :D
here's my current progress... sorry about the crap gif quality - fairly new to it... so basically i have a ragdoll crowd group i setup... then exported that out as alembic... then pulled it into this setup @mestela did for us and twiddled the values so the stiffness goes once they're knocked outwards :)  there's prob smarter ways but its working for me :)
and look!  look!  I did a gif!  screen2gif rocks :D
Edited by anthonymcgrath
  • Like 2
