Callback Has To Import Everytime?
Atom
Hi All,
I am playing around with Python callback script for buttons. I place this code in the edit parameter interface.
exec(kwargs['node'].parm('python').eval());refreshValue(kwargs['node'].parm('my_slider').eval())
This does work. But from what I can tell, this means that each time I press the button the entire python text is evaluated. So if I have a 2000 line python script in my node but I only want to run a 2 line def the entire script has to be evaluated before that happens.
Is there any way around this?
As a programmer I imagined that once I type code into a python node it becomes a local module and I should be able to target defs inside it, somehow? But that does not seem to be the case. The text in my python node is just a string until an event happens which cooks the node. Does this mean my python code simply falls out of scope at the end of every cook/refresh?
