Simple Math Problem
logix1390
I have a square geometry. 4 units on each side
using the measure sop it calculates :
perimeter = 16
area= 16
volume = 10.6667 ???????
How is Houdini coming up with this number for the volume. I know it's a square and it does not have a real volume but i'm curious to know how it came up with this number.
@logix1390 You have to put down an attribute promote, primitive to detail, with promotion method sum to get the real volume.
If I understand the help file correctly, the ˝volume˝ of each primitive is calculated based on the pyramid It forms between the face of your primitive to the point defined by the ˝center˝ value you give It. So adding the volume of all these pyramids together will give you the real volume of the object.
@konstatin_magnus A grid has no volume, I'm not sure what you are really trying to prove?
