Yon Posted October 15, 2016 Share Posted October 15, 2016 (edited) Hey, I noticed most of the OceanFX tanks are setup to inherit velocity from the wave deformer, will this be enough to make a seamless flip/ocean blend? Or do you need to apply the same displacements as well? Or, no inherited velocity and just displacement. Thanks if you can clear this up. Edited November 15, 2016 by Yon Anadeyo Quote Link to comment Share on other sites More sharing options...
Yon Posted November 15, 2016 Author Share Posted November 15, 2016 bump Quote Link to comment Share on other sites More sharing options...
tamagochy Posted November 16, 2016 Share Posted November 16, 2016 Nobody help with flip sim here. I use flip tank modified by ocean spectrum. After sim done you no need to use displacement from ocean. But when i try to use ocean surface shader on flip mesh it works wrong way. So there is no problem to blend ocean surface and flip but problem with shader foam. Quote Link to comment Share on other sites More sharing options...
Yon Posted November 17, 2016 Author Share Posted November 17, 2016 Ic, thanks for reply. I messaged CeeGee (Igor Zanic) who is well known for FLIP. He uses displacement on flip mesh. I think the shader will not work without maps because of the foam attribute. But with the simulation with ocean velocity's, and using maps at same time - will make a doubling effect and not blend? I am testing .. Quote Link to comment Share on other sites More sharing options...
tamagochy Posted November 18, 2016 Share Posted November 18, 2016 I use custom foam map for flip surface, but foam noise is change and strobbin... Quote Link to comment Share on other sites More sharing options...
