Waasha Posted October 17, 2016 Share Posted October 17, 2016 Hi everyone! I am currently learning F.E.M. (after avoiding it for years ) and I would like to pin few points of a solid object to an animated position. I saw there is a number of methods (using targetP, targetV, ...) but I was unable to make them work.. The Follow Target shelf tool on Solid shelf works weird, it asks only for the constrained object (my solid object), then for the constrained points (I select them on the solid object), but that's all! It doesn't ask for the object to actually follow! For the sake of simplicity - I created this simple test with two animated spheres and I would like the solid object between them to be stretched (the points of the solid object, that intersect with the spheres should be constrained to the animation of the spheres). I deleted all the "non-working" failed constrained nodes to make it clean. Can anyone point me in the right direction? Big thanks for any help! FEM_stretch_test_V01.hipnc Quote Link to comment Share on other sites More sharing options...
Stephen Posted October 27, 2016 Share Posted October 27, 2016 Sounds like what you are looking for is the "cloth attach constraint". You can find it on the cloth shelf as "attach to body", it will work with FEM. Quote Link to comment Share on other sites More sharing options...
