Access factory actions called by hotkeys
dotMov
I'm looking for a way to call the hotkey actions that ship with Houdini, for example "Home Selected" in the Network Editor context.  I'm not sure what an "action" really is, is it a method invoked via the HOM?  In this particular case I've tried using toolutils.homeToSelectionNetworkEditorsFor() but the behavior is not what I expect and would rather invoke the same "Home Selected" method that the hotkeys use via python.
  • 2 years later...
Ohh, I'd like to know as well.
In my case I'd like to know how to access the "Select Viewport" action, that you can run from viewport menu.
Alternatively I'd like to know if you can run an hotkey with python. (In my case it would be "N", which is assigned by default to the 'Select Viewport' action)
