art3mis Posted October 23, 2016 Share Posted October 23, 2016 (edited) Trying to create speed ramp effects in my sims going from normal to slow speed. I know about Scale Time for setting a constant time value but what would be the best way to build a SOP - DOP network for a time remapping effect to give the most flexibility? Would I need to use some combination of Timeblend and TimeShift SOPs? Edited October 23, 2016 by eco_bach Quote Link to comment Share on other sites More sharing options...
sweetdude09 Posted October 26, 2016 Share Posted October 26, 2016 Yo, not sure if you already found a solution but here's a quick set up that i made for a project a while back. It also allows you to offset the start frame of the sim too! Maybe someone smarter can clean up my expression. Right now it's using frames to ramp (since i was using baked sims), but you could easily adjust the expression for time as well. ODFORCE_TimeShifter.hiplc 1 Quote Link to comment Share on other sites More sharing options...
art3mis Posted October 26, 2016 Author Share Posted October 26, 2016 Thanks for sharing! Will have a look. Quote Link to comment Share on other sites More sharing options...
