Spherical Coordinates
sessionbeer
Hello,
I'm trying to replicate the same deformation as seen in the gif below. After some research I believe it's got something to do with Spherical Coordinates?
I implemented the formula from this site  which is:
radius = sqrt(x^2 + y^2 + z^2)
polar = arccos(z/radius)
azimuthal = atan2(y, x)
x = radius * sin(polar) * cos(azimuthal)
y = radius * sin(polar) * sin(azimuthal)
z = radius * cos(polar)
But this results in some pinching of the cube at both poles, so maybe this isn't right, or I haven't done it correctly?
Has any one got any experience with something like this? Any help would be really appreciated.
Thank you
sphere_deform.hipFetching info...
Edited by sessionbeer
Thanks @galagast and @mestelaUnfortunately I don't think either of those routes are right for this deformation, and after some more research I think I may have titled this post wrong. I'm not sure what the formula is called but I think this is getting pretty close to it:
float len = length(@P);
float a   = (fit(len, 0, 2, 0, $PI*0.5));
float r   = chf("radius");
f@x = r * cos(a);
f@y = r * sin(a);
@P.x *= @y;
@P.y *= @y;
@P.z  = @x*2;
I'm basically wrapping a disc shape around a sphere but using the centre point as the front of the sphere, and the sides of the disc as the back of the sphere. This looks like its close but I cant get the points to push out into a proper spherical shape? Can any one spot my silly mistake here and why I can't get the points out into the sphere shape?
Any help would be amazing as I'm so confused why its not working?
Thank you
sphere_wrapping_disc.hip
