benne5 Posted October 25, 2016 Share Posted October 25, 2016 Hi All, I am constructing some HDAs for Maya 2016. My object merges are showing up as “Edits” rather than “Set to Selections” in the Maya interface. Consequently I am unable input objects into the input on the Maya side. Anyone know a workaround or fix for this? Please see attached images and .HDA Any info would be much appreciated! test__inputsTest__1_1.hda Quote Link to comment Share on other sites More sharing options...
benne5 Posted October 25, 2016 Author Share Posted October 25, 2016 I discovered a work around. If when you initially collapse your tool it into an a subnet you have the desired amount of inputs already plugged into the rest of the tool the output on the maya side will work as expected. Quote Link to comment Share on other sites More sharing options...
