MrBrN197 Posted November 3, 2016 Share Posted November 3, 2016 Hello, I have a channel attribute I created and Want to set the maximum number in the "edit parameter Interface" to vary depending on the number of points in the attached object. So basically the $NPR would be the maximum number. Is there anyone I could do this because the maximun range slots only allow you to input numbers. Maybe some kind of python script?Insert other media Quote Link to comment Share on other sites More sharing options...
Atom Posted November 3, 2016 Share Posted November 3, 2016 Check out the parmTemplate. You may be able to modify the min/max after the fact in a callback script. http://www.sidefx.com/docs/houdini15.5/hom/hou/FloatParmTemplate Quote Link to comment Share on other sites More sharing options...
