ValentinD Posted November 4, 2016 Share Posted November 4, 2016 Hello everyone, I begin to use the take system in Houdini, it seems to be great but I have an issue. I have two simulation that I like in a Dop network, their parameters are setted with the take system. Once I want to export it, I lay down two dopIO node, set the "render with take" on each take, and press save to disk. If parameter "Valid Frame Range" is setted to save frame range, it worked great, but if I have the param setted on "Save current frame" it seems to render the current take (or Main take). Is anyone else having this bug or maybe I have done something wrong ? If someone else have this bug, is there a way to submit a bug to side effects ? Thanks ! Quote Link to comment Share on other sites More sharing options...
