Vex - attribute reading warning
SteveNi
Hi
So I have some Vex code and I keep getting this warning:
It says "implicit cast from float to int, use explicit cast instead".
Now I know this warning message, but I dont understand why Im getting it here, since Im dealing with vectors...the code works and everything, but I keep getting that and I don't know how to get rid of it.
Any hints?
Thanks.
You need to use type prefix on the first usage of @-binding inside wrangle: i@ptn will work. Without prefix, it will be defaulted to f@ptn or to the proper type, if the attribute name is something common (standard VEX/VOP variables and globals are recognized).
Edited by f1480187
I suppose you want to use @ptnum instead of @ptn for the number of the current point? Then the attribute is buitin and you do not need to prefix it.
And you can simplify the call a bit by replacing
attrib(1, "point", "up", @ptnum)
by
v@opinput1_up
This only works if you are requesting an attribute for the same point number from any input.
