art3mis Posted November 14, 2016 Share Posted November 14, 2016 (edited) Hi Having problems getting any whitewater showing up in a FLIP tank sim. As a start need to confirm exactly which node my whitewater_source > merge_fliptank node should be pointing to. Right now I have it pointing to /obj/fluidtank_initial/fluidtank Any FLIP experts that might confirm whether this is correct? I've attached the .hip file. no_whitewater.hiplc Edited November 14, 2016 by art3mis Quote Link to comment Share on other sites More sharing options...
rbowden Posted November 14, 2016 Share Posted November 14, 2016 You don't have it pointing to /obj/fluidtank_initial/fluidtank in the file you posted....You have it pointing to /ob/AutoDopNetwork/fliptank. In the default shelf setup, it would be pointing to the compressed cache file out node in the fluidtank_fluid node. I suggest changing it to that because I did and the source points for the whitewater started showing up. Quote Link to comment Share on other sites More sharing options...
art3mis Posted November 14, 2016 Author Share Posted November 14, 2016 Thanks Ryan! Will give that a try Quote Link to comment Share on other sites More sharing options...
