How to copy particles attributes between two POP Solvers?
catchyid
Inside a DOP network, I have two pop solvers A and B, each has its POP object/source. Source A emits particles, Source B emits particles from Source A. My question: I want Source B to inherit some particles attributes already in A, e.g. if a particle in source A has attribute f@density = 0.6, then if this particle were to emit another particle in Source B, then the new particle should have f@density = 0.6 as well.
I've tried to use VEX pop wrangler  f@density = pointattrib("/obj/smoke_particles_sim/popobject_A/Geometry", "density",@sourceptnum,i@r); but that did not work (I think the function is excepting a SOP object and not a DOP geometry)
Thanks,
I never emitted particles from particles this way, but normally a pop source adds all attributes from the source geometry. Just tested it and it works. So if you have an attribute called test in your popobject1, it should be automatically available in popobject2.
