mattjakob
Hello,
I am trying to do some edge detection using a kernel. I need to do this using standard SOPs/VOPs.
http://setosa.io/ev/image-kernels/
I saw a tutorial from Entagma (https://vimeo.com/169437381) that basically does the operation by hand splitting out the vectors and multiplying them but it's quite tedious and you dont really know what vectors you're multiplying (QUESTION: is there an order in which pcfind returns the array of points eg. clockwise closest to furthest ?)
Is there a better way (using actual matrices / knowing exactly which points) ?
thanks!
Hey Matt,
PCFind orders the points it returns by distance. As in that example we're searching through a grid with identical distances, I guess in the end it comes down to numerical errors (aka randomness) in which order the points will be returned. There are several ways to write a "proper" kernel, my approach would be VEX in a pointwrangle. However there is this quite stupid hack which allows you to abuse volume convolve in order to do kernel operations on a 2D plane...
Cheers ;)
Mo
Quick_Dirty_kernel_Hack.hipnc
  • Like 2
  • 4 years later...
