Bake render time into render
Can anyone tell me if there is someway to bake the actual render time into the final render?
Would be useful when testing the 'time cost' of different render settings.
Guess there would need to be some sort of a global timer mechanism that tracks the beginning of the render sequence and not just each frame that is output.
Again, doing a quick google search pulls up what you need to know:
http://forums.odforce.net/topic/18492-render-time-burn-in
You can also go under Extra Image Planes on your mantra rop and add the VEX variable Render_Time. This will make an AOV for render time and you can tell which pixel or group of pixels is taking the longest time to render.
