Uncompressed video export from MPlay and file size limits
art3mis
Hi
Encountering a strange bug when I try to simply export uncompressed video from Mplay.
The first 2 seconds are vertically offset so what should be on the top starts to appear from the bottom.
After the first 48 frames everything is fine.
Has anyone else encountered this?
This seems to be directly related to file size.
ie Exporting frames 1-200 resulting in a file size of  1.62 GB uncompressed video.
I can open directly in Windows by double clicking and also in Quicktime (although playback stutters due to file size)
However, if I try and increase the output of uncompressed HD video to 300 frames, I cannot open the resulting file!!
Could this be related to installed RAM? I have 32GB currently.
This also means a cumbersome workflow where I have to concatenate the output files using FFMPEG.
I also tried every possible compression codec from MPlay but they all have issues
Edited by art3mis
