Ranged random function
SteveNi
Hi
I want to randomly select two points from a geo input in a VEX wrangle, so far I have this:
int _selectedPts[];
_selectedPts[0] = rand(@numpt);
_selectedPts[1] = rand(@numpt);
setattrib(geoself(),"point", "Cd", _selectedPts[0], 0, {1,0,0}, "set");
setattrib(geoself(),"point", "Cd", _selectedPts[1], 0, {1,0,0}, "set");
I searched on the VEX docs but every random function I found could only return float numbers, but I need integer numbers.
How can I solve this?
What about something like this..?
int _selectedPts[];
_selectedPts[0] = int(fit01(rand(@ptnum),0,@numpt));
_selectedPts[1] = int(fit01(rand(@ptnum+311),0,@numpt));
rand() returns a float between 0 and 1. The fit01() remaps that into a range between 0 and number of points. Use the current point number as a random seed.
