bonassus Posted December 10, 2016 Share Posted December 10, 2016 I'm starting to learn Houdini. Im trying to import an image sequence via the Color Map node. It's a sequence of .tif files name filename_001 etc. the importer field in the Color map node picks up the $F3 in the file name but then it only shows the first frame of the sequence in even when I scrub the timeline. I can manually put in the single frame names for example filename_006 and the viewport updates to show the new image. But then when I change the Color Map file url back to include $F3 the image just shows a pink color. What am I missing here? thank you Quote Link to comment Share on other sites More sharing options...
bonsak Posted December 10, 2016 Share Posted December 10, 2016 (edited) Hard to tell but one test could be to promote the color map parameter on the Color Map node and enter the filepath on the outside. Animated parameters inside vops are not always stable. -b Edited December 10, 2016 by bonsak Quote Link to comment Share on other sites More sharing options...
bonassus Posted December 11, 2016 Author Share Posted December 11, 2016 That was it. Thank you very much! Quote Link to comment Share on other sites More sharing options...
