Uvunwrap
Im having an issue with UVUnwrap. In my object, I have a UVUnwrap SOP after my shader SOP but when I render out my unwrapped image the polys are not shaded. Any ideas as to what Im doing wrong?
Also, I can't figure out how to reapply my map. I have downloaded the Shader Unwrap .hip example but can't see exactly where it is done. I must be totally overlooking something but i cant figure out what. Any help would be appreciated.
Thanks,
L
  Jason said:
Make sure your UV's are VERTEX coordinates - thats the usual issue.  Which example did you use? The one from the Wiki?
18425[/snapback]
Yeah I used the example from the wiki. How do I make sure my UVs are vertex coordinates?
