Screenglow VFX Posted December 14, 2016 Share Posted December 14, 2016 Hi guys, I am working on tutorial and I have some issues shading an object at render time.It works fine for first object but not for the second.I have attached the file and video with problem.If anyone can help it will be awesome (trying for some time to fix it).Thank you guys. shader not working for second object.mov shader problem.hipnc viewport working on geo level.mov Quote Link to comment Share on other sites More sharing options...
thx1138 Posted January 19, 2017 Share Posted January 19, 2017 FIX: add "compliment SOP" after "threshold" parm in animation2 shader. And change colorramp to match the one from animation1_shader. Seems it works. shader problem_FIX.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Screenglow VFX Posted January 19, 2017 Author Share Posted January 19, 2017 Thanks. Will try this when I get back home and let you know. Quote Link to comment Share on other sites More sharing options...
Screenglow VFX Posted January 19, 2017 Author Share Posted January 19, 2017 tks thx1138 is working !!! I still have one more question to ask : what would be the easiest way to keep the same effect but have textures,bump maps applied to the models ? Quote Link to comment Share on other sites More sharing options...
thx1138 Posted January 25, 2017 Share Posted January 25, 2017 Maybe the easiest way to use noise as scale value for output F, Of and Af global variables. Quote Link to comment Share on other sites More sharing options...
