Change a Float Vector 3 to Select dropdown menu
art3mis
Hi
Just finished a digital asset course and trying to apply some of what I've learned. In a current scene I want to change the Float Vector 3 input values on the Add node to a Select menu drop down where I can hard code several different float values.
I know I should select the Add node, right click and Edit Parameter Interface but am stuck after that.
Edit Parameter Interface used for customizing parameters on selected node, which is what you usually do when working in Houdini or prototyping asset by promoting parameters on initial Subnet. To globally modify type, use Operator Type Properties located under Edit Parameter Interface menu item.
