chrsmith Posted June 1, 2005 Share Posted June 1, 2005 Hey guys, Ok, so now I'm trying to create SOPS using a tcl script. Using opscript, I can see basically what I want the script to do to build my SOPs. But a parameter in the SOP has a point() function rather than an explicit value. So in my script, I want to do this: hscript chkey -f 1 -v 0 -m 0 -A 0 -F 'point("../sort1", 0, "P", 0)' building/rangestart (simplified example) I get the message: "extra characters after close-quote", and have narrowed it down to the back-ticks, which I've tried to shield with a "\", but that doesn't work. Without them, I can't set the parameter value properly. So how do I work with the tcl interpreter and the hscript interpreter so that I can set a parameter to an expression? Any ideas? Thanks guys, you rock! BTW: Didn't mean to not thank you for help on the last problem. I had asked the same question on the sidefx forum and got an answer there and didn't check back here until just now. Quote Link to comment Share on other sites More sharing options...
