Seamless Noise VOP asset
Techie
Hi fleity!
OK, try the following:
1. Import the asset.
2. Switch to the COP/IMG network and create a VOP COP2 Generator node.
3. Open the VOP node, press tab and select Digital Assets > Seamless Noise.
4. Connect the global X and Y variables to the xParm and yParm on the Seamless Noise node and connect the noise output to the RGB outputs.
5. Hopefully you should see the noise on the Composite View tab now, otherwise try changing the Noise Type, that should trigger it to generate (not sure yet why this is needed).
Let me know if that helps! :)
Also see the attached example file which shows how to use it in both COP and SOP nodes.
seamless_noise_examples.hip
  • 4 years later...
The gumroad link is broken.
Anyways, just learned that periodic noises are also tileable; in which ways is this different? I am excited to learn about tileable noise.
EDIT: I found the gumroad link anyways via another road: https://gumroad.com/l/seamless_noise Thank you I'm gonna try these.
Edited by Krion
