Record Time Scrubbing (DJ Style Animation Sequence)?
Atom
Hi All,
I have a geometry sequence of a dancing character. I can scrub forward and backwards through the sequence in near real time. I like that kind of look and I wondered if there is a way to record my scrubbing of time into an attribute that changes over time?
After recording the scrub I could then use the attribute to drive the frame number of the sequence to load.
Is this possible in Houdini? I know After Effects has a similar control for recording the mouse into keyframes.
Thanks for the tips, I have come up with a CHOP solution that I think will work.
Locate a series of sequential frames in the timeline that you like, in my case it was frames 710-1410.
Create a CHOPs waveform in the form of a ramp with an amplitude equal to the number of frames, in my case 700.
Drop down a noise and a warp node in stretch mode. Ramp on left and noise on right.
This produces a pseudo random output in the range of 0-700.
Drop down a math node to map that range into the original preferred range, in my case 710-1410.
Now, anywhere along the time line I can get a ramp based random number between 710-1410. Because I am using this output as a frame number to drive my character when the noise goes negative time flows backwards for my animated character.
Edited by Atom
