Setting array attribute element via attribute wrangle
90okm
Hi ! trying to work with vex snippets and faced the problem !
I've created an integer array attribute on primitives and want to fill it with some values in attrib wrangle
but i always get the error message of "Ambiguous call to array index operator ''. Candidates are: 'float vector4[int]', 'float vector2[int]', 'float vector[int]'"
being declared within wrangle node the construction like this
i[]@arr = {};
@arr[0]=@primnum-21;
works fine
wrangle_error.hip
Edited by 90okm
Might be wrong, but if the attribute exists then it's just a statement what type of attribute you are trying to access, otherwise it has to guess what type of attribute is and it seems that it's not very good at it :)
It's not a bad practice to state the type of the attribute every time you want to work with it.
Here the list of known attributes which does not require type specified. As stated, all others will be assumed as floats. But you need to write type only once, later you may omit type:
v@test = {1, 1, 1};  // Type need to be specified once.
@test = 0;           // Still a vector assigment, will be set as {0, 0, 0}.
You also can declare attributes by writing full type name, in that case value will be used as default:
vector @test = {1, 2, 3};
