mageena Posted February 1, 2017 Share Posted February 1, 2017 hi all, i have an animated alpha sequence in trace sop causing point and polygon jitter when converted to the polygon . that making creating Voronoi fracture seems impossible. I've tried storing the animation, time freeze then transfer the animation back , but with no luck . any solution please ???? Quote Link to comment Share on other sites More sharing options...
Atom Posted February 1, 2017 Share Posted February 1, 2017 Try a Resample node after the Trace. This may lock down the point count which may be what is causing the jitter, a varying point count. Quote Link to comment Share on other sites More sharing options...
