Lukich Posted June 10, 2005 Share Posted June 10, 2005 hi there. i want to create a simple script that will create a renderer with predefined parameters (resolution, pixel aspect ratio, etc). it all looks fine except for one part - i'm trying to turn off micropolygon rendering (mantra -r). it seemed to me that the command to set it would be opset - r on mantra1 but it doesn't seem to be doing anything. do you guys know what am i doing wrong? thank you very much, luka Quote Link to comment Share on other sites More sharing options...
Lukich Posted June 10, 2005 Author Share Posted June 10, 2005 actually, if i do opscript, the -r option changes from off to on, but the change does not reflect in the Render Command line of a parameter window. does it mean it'll work? Quote Link to comment Share on other sites More sharing options...
rdms Posted June 10, 2005 Share Posted June 10, 2005 actually, if i do opscript, the -r option changes from off to on, but the change does not reflect in the Render Command line of a parameter window. does it mean it'll work? 18681[/snapback] You were on the right direction with the mantra -r. However, it's the opparm command you want to use. For example: opparm mantra1 command ( 'mantra -r' ) The '-r' option in opset is to toggle the render flag of an OP. Quote Link to comment Share on other sites More sharing options...
Lukich Posted June 11, 2005 Author Share Posted June 11, 2005 I see Thank you very mcuh! Quote Link to comment Share on other sites More sharing options...
