akarim770 Posted February 1, 2017 Share Posted February 1, 2017 Hi guys, I use Houdini apprentice v 15 and I wanted to render RBD as phantom but nothing works. And i need your help to fix the issue. On the first picture file_kitchen there is the phantom option and it works when i do a render. The second example is different when i select the dinner plate there is no phantom option like on the first picture. In the render visibility section i chose the phantom option and the dinner plate is still visible. Does someone know how to fix this ? Thanks you all. Quote Link to comment Share on other sites More sharing options...
Skybar Posted February 1, 2017 Share Posted February 1, 2017 Did you get that Geometry node from an old scenefile perhaps? On newer geo nodes it's in that dropdown menu called 'Render Visibility', and in this case you want to choose "Invisible to primary rays (phantom)". Quote Link to comment Share on other sites More sharing options...
davpe Posted February 1, 2017 Share Posted February 1, 2017 why don't you assign phantom object in your ROP (forced phantom)? that will override any other visibility options set anywhere. you don't have to dial anything on your objects. Quote Link to comment Share on other sites More sharing options...
davpe Posted February 1, 2017 Share Posted February 1, 2017 btw. you can add or remove any object options (like "Phantom" etc.) by "Edit rendering parameters" if you see something missing on any object it can be always modified this way Quote Link to comment Share on other sites More sharing options...
