Houdini phantom object
Hi guys,
I use Houdini apprentice v 15 and I wanted to render RBD as phantom but nothing works.  And i need your help to fix the issue.
On the first picture file_kitchen there is the phantom option and it works when i do a render. The second example is different when i select the dinner plate there is no phantom option like on the first picture.
In the render visibility section i chose the phantom option and the dinner plate is still visible.
Does someone know how to fix this ?
Thanks you all.
