TheUsualAlex Posted June 13, 2005 Share Posted June 13, 2005 I think it is possible to s/// on multiple buffers at once in Vi, but for the life of me, I can't remember how or find out what the command was. Anyone here happens to know...? Much thanks! Alex Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted June 13, 2005 Author Share Posted June 13, 2005 I guess :bufdo! %s/hello/there/g more or less worked.. : P Quote Link to comment Share on other sites More sharing options...
lisux Posted July 22, 2005 Share Posted July 22, 2005 Do you know if there is any sintax file for VIM and VEX? Quote Link to comment Share on other sites More sharing options...
George Posted July 24, 2005 Share Posted July 24, 2005 Do you know if there is any sintax file for VIM and VEX? 19726[/snapback] You can use the default C syntax file to get started, and add a few more keywords -- (and remove a whole bunch of stuff if you really want). Here's a link on how to create your own syntax files for vim: http://www.fleiner.com/vim/create.html Quote Link to comment Share on other sites More sharing options...
lisux Posted July 24, 2005 Share Posted July 24, 2005 You can use the default C syntax file to get started, and add a few more keywords -- (and remove a whole bunch of stuff if you really want).Here's a link on how to create your own syntax files for vim: http://www.fleiner.com/vim/create.html 19799[/snapback] Thanks George, i know i usually use the C syntax or the RSL syntax, the first is better. Hopefully side fx integrates the vim editor into the houdini string editor. Thanks for the info if sometime i have enough time to create a VEX syntax fille i'll share it. Quote Link to comment Share on other sites More sharing options...
