brucelay Posted June 16, 2005 Share Posted June 16, 2005 HI, Does anyone know how to apply different UV sets when doing rendering in Houdini with renderman I tried to use the "layer" sop to create defferent UVlayers. but it does not work when I use rman to render. I tried to put a "parameter" vop and used "uv" or "uv1" "uv2" for the param name in the shading network but it still doesn't work. Any help will be appreciated! thanks! Quote Link to comment Share on other sites More sharing options...
deecue Posted June 16, 2005 Share Posted June 16, 2005 try using the shading layer parameter vop instead of the parameter vop.. i can only assume renderman works the same but can say for sure.. Quote Link to comment Share on other sites More sharing options...
brucelay Posted June 16, 2005 Author Share Posted June 16, 2005 Dave, thank you for your suggestion but unfortunately in the rman section , there is no "shading layer vop"! yours faithfully brucelay try using the shading layer parameter vop instead of the parameter vop.. i can only assume renderman works the same but can say for sure.. 18831[/snapback] Quote Link to comment Share on other sites More sharing options...
