Old+New
Noobini
hmm...noob getting confused here...
Using H16 Apprentice, trying to do 'Group'>Operation: group by range...but can't find anywhere, so is it now 'Group by Range' node ?
Also Copy, is it now Copy Stamp ?
Nice to have a What's New section...be nicer to have a 'table' of old->new nodes...
Edited by Noobini
Group nodes now have been separated, per tab, more or less in the same way as the set of attribute SOPs
(which gives better performance if you only use 1 option in a group node)
Copy has a couple of variations now, choose whether you need stamping functionality or not, or if you just want to do more simple copying on points.
Or use the "Copy and Transform" node like the old duplicate (upon further inspection you realize both exist in the tab menu, but they create the same node ;) )
