onkardahare Posted February 26, 2017 Share Posted February 26, 2017 hi, i am working on houdini. Can someone help me understand the difference between Copy reference and Copy relative reference? I am confused when and in which particular scenarios should i use either of them? please help. any inputs will be appreciated. Quote Link to comment Share on other sites More sharing options...
haggi Posted February 26, 2017 Share Posted February 26, 2017 The difference is the path. "Copy reference" uses the absolute path to the attribute "/obj/geo1/pointsfromvolume1/particlesep" whereas "Relative reference" uses a relative path like "../pointsfromvolume1/particlesep". An absolute path will work everywhere in a network. e.g. if you copy a sop node and paste it into another network it will still work because it has an absolute reference. If you copy a sop with a relative path an paste it into another network the referenced node may not exist there an therefore the node may not find the correct reference. I think it is more a personal preference which one you use. 1 Quote Link to comment Share on other sites More sharing options...
pineapplepixels Posted February 22, 2018 Share Posted February 22, 2018 Using relative reference instead of using the absolute reference in a file node was the reason my file path kept passing a 0 and breaking my sim. Possible search terms to try and save someone a headache: houdini file node defaulting to 0 when referencing parameter Quote Link to comment Share on other sites More sharing options...
