celd Posted March 3, 2017 Share Posted March 3, 2017 Hi, I am rendering pyro with 2 extra image planes, combined lighting "all" with light exports, which gives me 3 passes - the smoke lit by 3 individual lights (direct, enviromental and volume light) and combined emission "all_emission" which gives me just the flames. Now all of this is very useful in compositing process, however it also increases render time to 8-15 times the length of render time without passes. I would expect there would not be any increase of render time since it already is a part of the "beauty" render. Is there any way to get around this? Thanks Quote Link to comment Share on other sites More sharing options...
Skybar Posted March 3, 2017 Share Posted March 3, 2017 Combined Emission is set to "Full Opacity Filtering" by default, and this is usually reaaaaaally damn slow when rendering volumes. There is no way to disable it if you enabled this pass with the checkbox, so uncheck that and instead add an extra image plane -> choose combined emission in the dropdown menu for "vex variable" -> change Sample Filter to "Opacity Filtering". It should bring down the rendertime to normal. Quote Link to comment Share on other sites More sharing options...
celd Posted March 3, 2017 Author Share Posted March 3, 2017 Thanks, I was hoping for this kind of solution, you saved us a lot of time! Quote Link to comment Share on other sites More sharing options...
