Save as
felo44
Someone know how to use "save as" in Pyhton?
Note: I'm looking for the same functionality as the "save as" under file drop menu. Therefore saveAsBackup() is not ideal.
Thanks,
Edited by felo44
I usually do something like this in that case:
originalFile = hou.hipFile.path()
# run the code I posted earlier to save the file here
hou.hipFile.setName(originalFile)
So after the code runs the file is reverted back to kind of an untouched state.
If you wanted to wrap that up into a saveAs() function it should be pretty easy
