Procedural Constraint Relationship
benne5
I have one packed primitive object which consists of several pieces of geo merged together. At sop level (before it is set to become a packed primitive) I have created a core group and an outer group.  I would like the core group (the red group)  to remained glued only to itself and the outer group(the green group) to be spring constrained to the inner group and itself.
The trick is how can I do this without manually blasting the undesired glue connections or using the delete by color method?  The reason being that I have very complex geo which is very close together.
I have a simple test set up .hip attached.  The real which geo I am actually working on it extremely full and chaotic.
Thanks!
packed_relationship_04.hip
