shrifazmy Posted March 25, 2017 Share Posted March 25, 2017 Hi I have a file been created within houdini 15.5 when i started to work on it with houdini 16 i git the attribute rename node changed like below and my network got error how can i solved and why dos it happened Quote Link to comment Share on other sites More sharing options...
shrifazmy Posted March 25, 2017 Author Share Posted March 25, 2017 It was going OK in the beginning but once i got this massage on opening Quote Link to comment Share on other sites More sharing options...
Atom Posted March 25, 2017 Share Posted March 25, 2017 (edited) Every new version of Houdini always produces some message when opening HIP files made on a previous version. This is mainly renamed fields and such. There is not much you can do. Just Click OK, save your file and move on. Edited March 25, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
shrifazmy Posted March 25, 2017 Author Share Posted March 25, 2017 Move on is not an option here the attribute rename is not working at all as you can see in the images so how this could be solved Quote Link to comment Share on other sites More sharing options...
Atom Posted March 25, 2017 Share Posted March 25, 2017 (edited) Have you tried deleting the troublesome node and dropping down a new version? If you can't move on then you may have to move back to the version of Houdini that generated the original HIP file. Edited March 25, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
shrifazmy Posted March 25, 2017 Author Share Posted March 25, 2017 yes i did and also i tested a full new file I got the same problem with this node at the beginning of the instillation it was Ok suddenly it changed like so Quote Link to comment Share on other sites More sharing options...
shrifazmy Posted March 25, 2017 Author Share Posted March 25, 2017 I got it the problem was the operator definition is not correct it was pointing to something else so i was have to correct it and direct it the original one thanks Quote Link to comment Share on other sites More sharing options...
